B&S 40N877 engine is surging most noticably at idle and low speed, but even at high speed it does not sound right. Sounds a bit rough.
Mower has less than 30 hours on it. 2 years old.
New fuel filter, air filter, spark plugs (old ones looked fine)
Fuel pump seems to work fine. I see fuel trickling into the filter. Crank the engine with the pump output line disconnected and gas spurts out pretty vigorously.
Just for kicks I gravity fed fuel from a container - no difference.
Opened up the carburetor - it looked perfectly clean. Blew out the orifices and re-assembled. This carb has a single emulsion tube, not the 2-tube version I've seen in several youtube videos.
Governor linkage and springs all good.
Fresh fuel (although it is 10% ethanol).
Read lots of posts here and in other forums about engine surging and I'm running out of things to check.
The mower runs ok at high speed and is perfectly usable, but just doesn't sound like its running smoothly. At its lowest speed it lopes badly, almost stalls.
Its still under warranty but a hassle to bring it to a JD service center. Plus, if they determine it just needed a "tune-up", i.e. normal maintenance, that's not covered.
Any ideas?
-Jon Usually when they surge, it could be a plugged passage in the carb, Soaking or sonic cleaning works the best, you did not post the Type or code number from the engine, most of those 40 cubic inch engines have a Nikki carb on them, If the static timing of the governor is correct, it usually will be the carb that is the problem making them surge and run rough, and yes, they had their share of problems with those Nikki carbs, those O-rings can be a real problem, B&S only warranties the carbs from 90 days of DOP. Make sure your intake gaskets are good, they use either a red square O-ring or a gasket. The approx. price on those carbs is 212$, Without the Type and code i cannot tell you the correct carb P/N. Just so you know, I have been a B&S dealer for 50 years. Plus, if i remember right, there is no carb Rebuild kits for them, {Nikki} all parts are sold individually. I Hope this helps; My Business E-mail is
[email protected]
