Z254F Deck Adjustment Question
Pete-MKCS
Location
West Point, TX
Owners of the Husqvarna Zero Turn mowers, do you have to push the deck level adjusting hard to set it in the No.1 and No.2 position. Most mowers drop to those positions using just gravity, but mine seems to have a lot of tension against the lever when lowering the deck to the 1 an2 position. So, is this normal?
Yes
It is all about the strength of the deck lift assistance spring
Without one you could not lift the deck at all
Big decks have 2 small decks have one .
Thanks Bertsmobile1, it just seemed strange that there was less spring tension at position 3 and 4 and it required pushing hard to get it into positions 1 and 2. Thanks again.
