Z force Will 60” mower fit on 64” trailer
Elevatorbri
I have a trailer with an interior width of 64"
I am looking at the z force steering wheel mowers
Will the 60" fit? Or do I have to get the 54", , maybe there
are attachments that must be removed.
Thanks for any assistance!
7394
IDK ? But if you google up your model it should show the specs, including width with chute up.
Elevatorbri
I couldn't find the info on the Cub cadet website
If it is just for the occcasional trip it will fit if you tie the chute back or remove it.
If you are thinking of doing it daily it will wreck both the deck & the trailer.
A 60" deck is going going to measure really close to 64" if not just a hair over.
Should be 1/2" between the blades & the side of the deck then 1/2" to 3/4" for the deck depending upon what sort of reinforcing there is around the lip so yes it will be very tight
reynoldston
Not going to fit, my trailer is 64" and I can't put a 60" mower on it. This is the reason I own two trailers.
Elevatorbri
Thanks everyone for the input, much appreciated!.it would only be used to take it in for service and to get it home initially.
My service trailer is only 54" wide.
For stuff bigger than that I use the motorcycle trailer with some ramps so the mower sits over the wheels or take the deck off completely.
Not real easy with the big fabricated decks but always an option.
On ZTR's all of the decks will slide in longways under the mower.
