start the engine and let the parking brake off
Raise your butt off the seat , the engine should stop
Do the same with the parking brake on, the engine should not stop
IF it does then the seat switch or the switch plug is faulty
Husqvarna use a "tamper proof" plug to prevent idiots by passing the seat switch
The plug causes a lot of problems like this
Flood it with contact cleaner, brake cleaner degreaser, Wd 40 etc etc etc then plug it in & unplug it many times
Then push it tight together and secure with a zip tie done up tight
