mower that was parked after pto switch pulled out of its housing mice built nest dogs went after mice and tore the wiring harness up mostly repaired (solder and shrink tubing can't stand mashed together ****)problem now is charging system have no wires to regulator or the red connector/diode wiring diagram says it feeds red wire have connector 2 wir that comes out of 6 wire connecor ( about 3 inches ) with red wire and orange wire this is below solonoid wiring diagram shows orange feeding headlights probably can figure it out when i get it running problem now is starter dogs ripped off stud where battery cable connects tried shadetree repair did not work need a brush assembly or another starter question there is what numbers do u use numbers on bracket are 050413ch i have seen on this forum about an 445677 which is faster any briggs starter experts here thanks in advance
