YTH 2148 will not start
alan081954
If I jump start the mower it will start and run. If I let off the brake it dies. without the jump it will not start at all. the battery is good with a full charge. I've test the solinoid and it is good. I have seen other things mention that the "brake saftey switch" is bad or out of adjustment. can anyone tell me where it is located or what my problem can be?
Carscw
Also look at the switch on the seat
alan081954
fuse is good, bypassed the seat switch (jumper) looked at wiring diagram and mower and see no switch near the brake pedal.:frown: if i jump it with the car it will start but dies when the brake is released. this has run fine until now. :ashamed:
alan081954
can anyone tell me where the brake switch is located? I just don't see one anywhere at all:frown:
Carscw
The brake switch will be around the brake pedal under the mower
