Covy
- Aug 12, 2020
- 7
One more test. With a 4 terminal solenoid remove the small wire from the small ground terminal on the solenoid and if possible run a ground wire from this terminal to battery negative terminal. If you can’t do this, run this jumper to a good chassis ground. Now repeat the third and fourth tests I posted. If you still have 0 voltage at the large solenoid terminal going to the starter, bod solenoid. I know I shouldn’t do this, but I’m assuming you have also tested the starter by running a heavy wire jumper from battery + terminal to starter terminal and this will turn the engine over?? Am I right??
Sorry for the delay, had my son's baseball to watch last night.
Ran the same test with the solenoid grounded to the negative post of the battery.
First note: Overnight the battery power jumped up such that it was nearly 15VDC (I had the chassis ground pulled from the negative post). I put the chassis ground back on and it went down slowly to about 12.5.
3rd and 4th tests both produced 0V
I also tested with a jumper (not a heavy wire, though):
- Kept the voltmeter across the battery terminals
- Pulled the Solenoid wire off which leads to the starter
- Used jumper (probably 24 AWG) from battery positive post to wire leading to starter - Nothing happened
- Used jumper from battery positive post to starter post - Nothing happened
