YT 3000 is smoking
Nov
My yt 3000 has white smoke with some dark but mostly white.
It runs and sounds good except for a bit of sputtering. Oil was blowing out of the oil drain tube, but i stopped that with a gasket under lid, not sure if it's supposed to have one.
It smokes mostly under a load with blades engaged, not much in neutral.
Is there anything besides worn rings that can cause this?
Blown head gasket
Fuel leaking into sump thinning the oil
