PTmowerMech
- Apr 16, 2018
- 424
- 3,242
Something to consider.
Small engines are the least of the worries, when you have rich uppitys flying around on private jets,telling us small engines are the problemTalk about BS statistics
If you feel like having fun work out the actual volume of exhausts of your leaf blower ( a tool I have always thought we could do without ) Capacity x revs x time then do the same for your vehicle and divide it by 2 because it is a 4 stroke
Note they used "avarage car " so that can be used to eliminate all of those 10Litre SUV's but even if the "average car" was a Diahatsu Charade or Suzuki swift with a 1200cc engine those numbers just do not stack up.
Perhaps "average" is a Prius
And to put some perspective on the 2,000,000 tons per year that would be about what is generated EVERY DAY at large airports and their emissions are far worse as most large jets spew out 100 gallons of unburned jet A1 fuel out the exhaust every time they take off , so a 4 engine jet = 400 gallons x 200 take offs a day on top of the exhaust , and remember jet fuel consumption is usually measured in tons per flight .
I have not seen a break down according to source for the USA but in Australia road transport vehicles ( car trucks & motorcycles ) is 13% of our total outputs . Home power equipment is 0.05%.
To put it politely
Urinating into the wind
But you can dress it up to make it look like there is a real benefit
FWIW
I drive an 2.4L L300 van on LPG
Cruising speed is 3000 rpm
so 3000 x 2400 / 2 = 3,600,000 litres of exhaust per minute
My mower is a 160cc Victa which runs at 3600 rpm
so 160 x 3600 = 576,000 litres of exhaust per minute
thus 1 minute behind the wheel is 6 minutes on the grass
For a average leaf blower I would go for 30cc although most I work on are less than that
so 30 x 10,000 ( few actually run that fast ) = 300,000 l/min
Thus 1 minute behind the wheel = 12 minutes behind a leaf blower
Batteries whether they be electric vehicles, or mower and handheld equipment, are a government, media, corporate push. The term “follow the money” probably applies here also. It will be interesting to see how all this works out over the next, say five years.Now you US folks could have some fun here and send Home Depot letters asking their "environment officer" to justify his outrageous claims
Include the calculations for your own vehicles & tool then finish off with a comment to the effect of
"If this is the level of lies & deceipt that Home depot has stooped to the I must consider weather I or any of my family can believe anything you print and thus do our shopping elsewhere "
As Arlo Guthrie suggested
1 person is probably sick
2 people are sick & know each other
3 people is an organization
50 people is a movement and perhaps they will realize that while you can fool some of the people some of the time you can not fool all of the people all of the time .
"My battery powered mower is cleaner than your battery powered mower."
And we are most polluting animal on the planet too. We are even changing the planet's rotational axis tilt by sucking so much ground water.
