PTmowerMech
- Apr 16, 2018
- 423
- 3,233
Pretty cook homemade device for testing and maybe even fixing fouled plugs.
If you really want to test a spark plug you need a tester like this. It is used to test and document aviation plugs. No offense but the box the guy sent taryl is just a spark box. Actually kinda useless an it doesn't test plug under compression.
SPARK PLUG TEST CT475AV 110V | Aircraft Spruce
SPARK PLUG TEST CT475AV 110V Designed to clean and test all 14mm & 18mm massive and fine-wire electrode aviation sparkplugs.www.aircraftspruce.com
sounds more like the wrong plug is installed if it's misfiring under compression...Not to make this a TLDR. Aircraft spark plugs are very expensive.
CHAMPION SPARK PLUG REM40E (BOX OF 12) | Aircraft Spruce
CHAMPION SPARK PLUG REM40E (BOX OF 12) All Champion Aviation Spark Plugs are identified by type designations selected by virtue of the plug design as applied to the following Spark Plug Number and Symbol Chart. The symbol is composed...www.aircraftspruce.com
When doing aircraft annual inspection the plugs have to be tested and documented and the champion machine is what you would use. Overkill for a mower shop where you just change a $2 plug if there is any question vs $$$ to change aircraft plugs.
Plugs that work in air may misfire under compression.
that guy is a nitwit, i.e. "this was homemade, there's no brand name, etc."; hmmm, maybe he could have just looked at that shiny silver metal manufacturers label under his right hand that says: Jefferson Electric Luminous Tube Transformer. Maybe he should just find himself a real vintage Champion spark plug tester/cleaner. Maybe.....Pretty cook homemade device for testing and maybe even fixing fouled plugs.
No.sounds more like the wrong plug is installed if it's misfiring under compression...
more compression increases heat and requires colder plug, just say'n...
