Yazoo jack shaft failure/repair
1pep
Seeing the brand name, most know parts for this machine are not to be found.
The first picture, arrow shows the part that has failed.
Next show it remove and damage, cast failed
Starting with a good size aluminum chunk 4 x 8 x 8, cut a piece 4 x 4 x 8
Second cut horizontal bandsaw, reduce that to 4 x 4 x 3.5
Next step will be to mill and size the for layout and machining.
More to come
pep
I can see what you are doing but that is a big lump of expensive aluminium you are about to turn into shavings.
Another way would be to bend a length of flat bar into a U shape close to the sprocket & the pulley then put a pair of self aligning bearings at each end which would counter the twisting moment which caused the cast bearing carrier to fail in the first place as you are supporting the shaft closer to each end.
Could even use 2 pieces of flat plate if you could drill 2 mounting holes in the vertical section of the bar that the casting bolts on to.
Realizing that we do what we do with what we have at hand at the time.
Looking forward to the completed support.
1pep
Moving along squared the the block and ruffed out a working billet.
Chucked it, checked center, next drill, size and fit the main bearing hole in hole
pep
Boobala
Hey pep, that's some nice machinery, and pretty nice work too, are you a machinist by trade .. ??
EngineMan
A pipe with two bearings one at each end would also work, but I'll let you do the job you are doing...!:thumbsup:
cashman
What kills those jackshaft housings is the chain is too tight when the self propel is engaged. When you go to reassemble it, make sure that the chain isn't too tight when you engage the self propel. The chain doesn't have to be real tight and a little slack won't hurt at all. The chain is a regular #35 chain and the shaft and bearing is the same one from a water pump used on a 289ci Ford.
1pep
Boo,
Not a machinist, an IT guy currently. My natural born talent is mechanical, was a typical kid with the cars and the midnight drags. Street outlaws are not the first :laughing:
EngineMan,
Good idea was thinking JB weld to hold everything together wah da ya think? LOL
cashman,
That very well could be true, but the chain had slack running in it. Have a grade along the front mowing up, as the mower rolls back down. Was using the drive as a power brake, that's what I think killed it.
That block of aluminum is 6061 dense and stout should hold up.
Starting to take shape, bearing hole machined and fitted.
Finish shape determined and marked. Back to the band saw and get the general shape cut out.
The holes are reliefs for the band saw cuts, and a corner radius. The center punched mark, will be where a pointed set screw will thread. It purpose is to capture the bearing, to prevent it from walking.
pep
cpurvis
An IT guy with Prussian Blue...I love it.
1pep
Pretty much there .....
Back from the band saw, sides and mount pads trimmed too ruff size.
Some light milling to follow, machine the sides and mounting pads. Once milled to size, slot the mounting pabs. Drill and tap for allen screw with point that fits the slot seen on the bearings.
Paint mount adjust chain tesion, start the mower for a run test
pep
