Hi all,
I fixed the hydrostatic trans on the mower and now have full drive power..yay (very small win but this gal is proud of my acheivements
But now i have a question regarding the engine double pulley and i'm hoping you knowledgeable folks will be able to help. when mowing after a while the deck belt around the engine pulley starts smoking. The drive belt does'nt just the deck belt now am i right in thinking its either the tensioner spring possibly stretched (it is old and rusty) the belt that is stretched (seems to be a brand new belt)..or the engine pulley is damaged?
i will replace both the belt and the spring with new ones, but i'm thinking longterm of getting a spare engine pulley or a zombified (if thats even a thing) one to have on hand should the need arise.
I can turn the pulley by hand no issues at all so i know its turning, if it is damaged then that leads to my next question. i believe the part number i need is 756-0636 unfortunatley this seems to be no longer available, would any of you know of anywhere i might be able to find one of these and if not is there any other double pulley for any machine which i would be able to swap into my machine that you know of?
Last of all if no alternative pulley is available is there a way a pulley of a different size could be used? (i've seen people on youtube fitting different sized pulleys but its beyond my capabilities so who could i ask?)
At the end of the day i just want a mower that will cut my grass i don't want a racing mower or anything fancy.
any help would be greatly appreciated thanks in advance.
Lea
Lea
