Last year I broke my lower drive belt and purchased a new one from TSC. I put it on like the instructions said, but it slipped quite a bit going uphill and was going slow over the lawn. The last mow of the year it slipped and turned sideways. This damaged (gouged/cracked) the belt beyond limits. I just got a new belt (754-0467) for the spring. I installed it and this time it is so loose it will not even engage. I adjusted the idler rod (747-1127) all the way back to try to get it to engage, but no good. Any ideas on what to do next? Thanks!
