Yard machine keeps dying.
Throttle linkage and spring will be loose until the engine start to rev up.
Jdtbolding
Well tonight I tried starting it. Just kept turning over til the battery died. Carb and pump seems fine. Has some gas spitting up from the carb and has spark.
Jdtbolding
Ok I spoke a little too soon. As soon as I had some juice in the battery it fired right up. Ran for about 45 minutes while I cut my front yard. Ran like a top. No sputtering not even a hiccup. Moved the throttle down to half and it kids started spitting but I'm ok with that I just won't move the throttle. Thanks a lot for all the help fellas!
Jdtbolding
Although it still won't start when it's hot. I guess ill chang the coil and see if that helps.
