XT2 gx54 wont start
gbj54
Every time I try to start it the engine turns over once or twice then nothing happens. I have tried a new battery and starter. I have also bypassed the solenoid and made sure there was a good ground but nothing seems to work. Any suggestions would be helpful.
remove the spark plug & try cranking the engine again
Engine cranks quickly = ACR not working, adjust the valves
fuel spurts out of plug hole + bad float needle in carb,
If this reply looks familiar it is because it is the exact same reply to our other post in the engine section.
Please do not double post it just gets confusing for you and everyone else.
