X380 fault code 9000.
lpfam11
Have a X380 that will not start. We ran the on board diagnostics and it keeps pulling up a 9000 code which is “reverse pedal pressed”. The reverse pedal is not pressed and even tried pressing the forward pedal to pull the reverse pedal up. Still has the 9000 code no matter what we do. Looked for pedal sensors but do not see any. Any ideas?
mechanic mark
Either purchase Technical Manual & troubleshoot & make repair or take to Dealer & let a Factory Certified Technician make repair for a small fee.
Reverse sensor is generally on the rear axel and will be wired in with the seat switch so follow the seat wires under the rear guard.
The switch & how it works will be obvious
And a triple + to Marks suggestion about buying the JD tech manual
Except in this case the switch is on the forward/reverse assy. Probably in or under the operator's tower.
