x304 engine oil leak
jerboy
where can i get a free repair manual for this engine, I think it is leaking around the oil pan. Has anyone tried oil stop leak in there mowers? Thanks
What engine??? It would be a whole lot easier to help you if you gave us info like engine brand, numbers etc.
Scrubcadet10
Moderator
Staff member
I think it uses a Kawasaki FH 2 cylinder,or an FS 2 cylinder depending on the year model.
First thing i would do is clean the engine real good. Especially where the oil leak is evident.
Brake parts cleaner is good at cutting the oil and dirt.
jerboy
thanks for the reply, it is a fs 2 cyl
