J jerboy Forum Newbie Jan 1, 2021 #1 where can i get a free repair manual for this engine, I think it is leaking around the oil pan. Has anyone tried oil stop leak in there mowers? Thanks
R Rivets Lawn Royalty Jan 1, 2021 #2 What engine??? It would be a whole lot easier to help you if you gave us info like engine brand, numbers etc.
Scrubcadet10 Moderator Staff member Jan 1, 2021 #3 I think it uses a Kawasaki FH 2 cylinder,or an FS 2 cylinder depending on the year model. First thing i would do is clean the engine real good. Especially where the oil leak is evident. Brake parts cleaner is good at cutting the oil and dirt.
StarTech Lawn Royalty Jan 2, 2021 #5 jerboy said: where can i get a free repair manual for this engine, I think it is leaking around the oil pan. Has anyone tried oil stop leak in there mowers? Thanks Click to expand... One or two of us maybe..... You have either the FS541V or FS600V. You clean the engine and use an UV tracer dye to find the leak source first but that just me. Engine Service Manual https://www.mymowerparts.com/pdf/Kawasaki-Service-and-Repair-Manuals/FS600V-FS541V-FS481V-99924-2094-01.pdf
