Would this be worth getting fixed?
Sorry it's taken me so long to reply, the last couple of weeks have been crazy busy.
It's much cheaper to hire it done that buying a triple bladed RV, storing it, maintaining it and the fuel cost. No upkeep, sit on the couch drinking a cool one watching the game. Enjoy life why don't ya'.
I was seriously considering that, though I'm hesitant because our jungle yard is basically a nightmare of hidden roots/stumps/other hazards that only I know how to safely navigate a mower through. Afraid I might have to pay for damages if anyone else tries to mow it.
Or one could snag say an older Craftsman lawn tractor off facetrash marketplace for peanuts. Swap the engine out. Most of the time the mower is junk with a good engine.
Ugh, anything but that. Is there anywhere else one could find a used mower?
I am glad you have that issue. Most of the junk mowers that I come across look showroom clean and have unannounced rapid self disassembled engines
Spend whatever it takes to clean up the yard making it free of mowing hazards.
Last time I mowed with my Toro (model 74353 (engine model 31H777-0168-E1 if I'm reading this right)) it had difficulty starting, ran a little louder than normal, died on me within 5-10 minutes and wouldn't restart. Checking it I found it was low/out of oil, so I think it had developed an oil leak, though maybe I just didn't tighten the filter enough last time I changed it. It still wouldn't start after refilling the oil, the engine turns but doesn't catch. There does seem to be more oil leaking on and underneath the engine since.
I can do basic maintenance on it but removing and disassembling the engine is beyond me. Any idea how expensive this would be to get fixed/replaced at a shop? Or would it be cheaper to just get a new mower at this point? I should mention we're probably only going to need a big, triple bladed Delta Executor riding mower for a few more years at the most.
How expensive this would be to get fixed/replaced at a shop?
Since it has been very poorly maintained, not likely. Expensive repairs - $500 + to fix Oil leak, sharpen blades, check belts etc. Get Compression checked FIRST if going the repair route.
Dying from oil starvation usually means the engine is totally fried. A shop will easily charge $800+ for a swap or rebuild. Before you scrap it, take a good look at your mower deck. If the shell is solid, you can just buy a used engine online and bolt it on yourself. But if the deck is trashed too, just buy a new mower. I usually get my replacement spindles and belts from http://udcparts.com/
But if you have to rebuild both the engine and the deck, it's definitely not worth the headache.
Do those mowers have a Low Oil Pressure Switch? Put a 'Check Oil First' sticker on the engine..
There should be some electronics that won't allow starting unless you do.. GREAT IDEA
My commercial Pro Z 154 has a commercial Kohler Confidant engine. It didn't come with an oil pressure switch, but it had the port on the block for one, and the engine harness had a connection for one. So I added one. I did more research, and found out that this OP switch will prevent an engine from starting with low oil, but it won't shut down a running engine if oil pressure is lost. This is a commercial engine. I seriously doubt that a non-commercial engine would have an oil pressure switch, and even if it did, it wouldn't shut down the engine when oil pressure is lost.
