Coca Kohler
The tires currently on my mower are 16x6-8 which are useless In anything but dry weather. I don't use the mower for cutting grass it's used for a towing tractor and a bit if fun. I found some cheap tyres sized at 22x11-8 which I was wondering if they would fit on a standard 8" mower wheel with an inner tube. The mower i want to put it on is a husqvarna lt100 with lifted fenders and a 4 speed peerless axle. The only worry I have about the increase in size is the width which look like may be a tight fit with the large width of the tire.
