WhyZed
- May 11, 2013
- 6
- 109
Honda 5.5HP Pressure Washer with cheepo pump.
Has done the job I purchased it for, for the last 8 or 9 years but last fall it stopped pumping. (Motors always been a pig on fuel but it always started).
I'm in desperate need of my ol' trusty washer so I dug into the pump thinking the cheapo pump was the problem. All the ports were clean, all the valves were good, all the seals looked decent so I greased er up, fresh oil and hooked er back to the motor & the hose but still no pressure. :confused3:
Pulled the pump off the motor (in a different spot) and found the 'woodruff key' ground down to the keyway and the crank broken
Crankshaft.
Whats left of the key!
Is the quick solution to this to JB weld the crankshaft back into original shape and reset the key.
I set the original Key against the flywheel magnet and it is ferrous. I would have thought they'd put an aluminum Key in there, more sacrificial and less damaging.
So wheres a good place to get a replacement Key?
I can turn the 'washer pump' with my fingers, so why would the crankshaft keyhole sheer off like that?
Regards,
Zed.
Crankshaft.
Regards,
Zed.
