Wood floor for trailer
Ric
Really a difference of 50-100lbs won't be very noticeable, use what you have and fits your budget, 2" is abit over kill but makes it pretty easy to swap out a plank If it breaks
I agree a difference of 50-100lbs may not be noticeable on some trailers but with a 5x8 it could make a difference. The 5/4 would be enough for a 5x8 trailer and it would be half the cost to replace.
RoperGuy
I agree with you Ric unless he already has useable wood, that would be my route , also it would be worth stoping in at your local mill, generally priced better then the building centres
Skydragon750
Well here is the result with 2x10. Just need a 2x4 in the middle to finish. It's treated wood but i painted to insure it will last. Made a angle cut to help riding up on the wood and the ZTR cellars with no touching.
I can tell the difference in weight by pushing it around.
exotion
<img src="http://www.lawnmowerforum.com/attachments/commercial-residential-lawn-mowing/25334-wood-floor-trailer-image-3135608584-jpg"/>
Should have spaced those more wouldn't need the 2x4 and would help with debris and water
7394
If you really wanna keep weight down, only add 2 strips on each side for the mower wheels, leave rest open mesh.
Ric
Wow HC icon_scratch.png (interesting)
Boobala
WOW !!!! Black & Blue, My colors ...... after the wifey gives me HER point of view !! ..... :laughing: ..:laughing: ...:laughing: ...... Boobala
