Mad Mackie
- Jul 11, 2011
- 1,851
The majority of Scag machines have a cranking relay. when all the safety circuit parameters are correct, the electronic control module will allow a ground path for the cranking relay to close when power from the key switch in the start position goes to the cranking relay.
When a Scag with a cranking relay has a starting problem and the engine is cranked over for prolonged periods of time, the contacts in the relay get burned.
I keep a spare in my trailer along with the tools to remove the panel as the relay is under the panel close to the key switch.
