Update! -No compression in either cylinder. Guessing head gasket? Worth repair or get new motor?
Hi. I have a Husqvarna mzt61. Fired it up, engaged pto. Blades spun. Through earmuffs sounded rough\racket and maybe weak. I shut it down. After looking things over, it will not start. Cranks strong. Would bad pro clutch keep it from starting? Fuses good. Blades don't spin when cranking.
