Wont start. Bad pto clutch?
RevB
Sounds like broken cam?
Briggs motor. Oil is good. Sound from what i recall was a clunking or grinding. I noticed right before that it seemed weak. I only made it about 50 feet, engaged the pto, heard problems then shut it down. High hours. I just got it used. Thanks
biggertv
I swapped a 22HP Kawasaki twin for a Briggs 21 HP single on a Cub Cadet RZT50. Wiring harness plugged in all correct, Shaft length and diameter all matched up. Plug and play. Kawasaki had hole in block. Push rods are Puny compared to the Briggs. Gotta keep these motors clean and full of oil or else...
