Won't crank/ no fire
victoriffic
I have a 2007 Scag Wildcat, which has been a perfect piece of equipment untill now. After sitting in the barn all winter, the original battery was dead. I jump started the engine (26 hp Kaw ) and it started right up. When I disconnected the jumper cables it died......after that it will not crank nor is their any spark when I jump across the starter with the key on.
All the interlocks check good, I found a diode on the wiring diagram and finally found it buried in the wiring harness, it test good. The starter relay is good and I even swaped it with another to verify this.
Grass is 12" tall......Help
KennyV
Are you saying it is not working with the dead battery... but did work while you were connected to a good battery?? :smile:KennyV
Briana
Hi and WELCOME to LawnMowerForum!! I have moved your thread to the Small Engine & Mower Repair Forum. You'll have better luck getting assistance there. :thumbsup:
jeff
Does it have a fuze?
