Cusser
- May 3, 2019
- 14
- 225
Sure sounds like bad battery to me, if connections are all clean and tight. In the test above (battery voltage while trying to start), the minimum is 9.6 volts for automotive testing.Finally got a chance to check it today.
12.5 at rest. 7.6 when trying to start. Does that mean battery getting bad?
jerry
Question: did you try a jump start using cables from your automobile? If it cranks/starts then you've demonstrated by testing that your mower battery is bad.
