Wit's end
SHasty
Help 25 up Kohler spiting and popping back through carb when starting And finally starts after spinning awhile then seems to run fine. Sounds like valve adjustment but have checked 3 times any ideas ??
A sticking inlet valve or loose inlet guide or seat will cause these symptoms as will a fractured flywheel key.
So as already mentioned you need to look at the head.
And as also mentioned we nee the engine make & model number in order to give you anything else other than generic advice.
