wisconsin motor
double yellow
Grand son bought an od sears tractor 70 year. which some one put a wisconsin motor on it, When he enguages the mowere bnlades the motor dies. There is no safety switch on the tractor, Starts and runs fine. Any ideas what might be the problem
Thanks for any help
Numerous things float to the top. Belt/pulley/idler/tensioner/bearing issues. Plugged up carb. Weak spark/coil. Dirty plug. Water in the fuel. Cylinder full of carbon. Valves need adjustment or a valve job. Compression test. Total health and welfare check on the ol' girl. Old gas. on and on and on.
1.Does it have compression? Pull the rope. Is it hard to pull? If so move to #2.
2.Air filter usable? If so move to #3.
3.Dump and flush out the fuel tank. Install new fuel lines to the carb. Boil clean the carb. Steady flow of fuel AT the carb inlet.
4.Strong spark UNDER LOAD? Gap an old plug 1/4" wide. Does it jump that obtuse gap?
Ether the governor is not working or there is too much resistance in the blades
Chock the wheels and try to move which will load up the motor
Did the engine stall out ?
Take the blade belt off and see if it stalls out again
Let us know what happens.
double yellow
Thanks. I will tell my grandson
double yellow
Sure will see what we come up with
Thanks
double yellow
double yellow
He said he solved the problem, But he did not say what the problem was, Will check
Thanks for the help
