At times in South Alabama if you cut much grass and stay caught up you will have to cut not only wet grass but at times even in the rain. Some times in July and August it rains every day. If you have many yards you either cut it wet or you don't cut it at all. Leaving it alone till it is dry is not an option cause it could be kneed deep or higher before it stops raining long enough to cut it dry.
And the longer you wait, the longer it will take the grass to dry, since it will be so tall and thick! :ashamed: Sometimes after a full sunny/hot day the grass might still be damp!
Exactly and you run at what ever speed that the mower will cut it. My Kubota is a side discharge and I cut in the rain several times last year. As for getting the grass out I have run it through standing water with the blades in gear. Also one more thing is when you shut it down get the grass off before it has time to dry if that is an option.
Yes, for my mowers I use a putty knife (since the underside of the deck is a lot smaller than your Kutoba) to get the grass out from under the deck. I try to do it when it's still moist, but it works well when it's dry, also. I used to use the one on the left (see picture), but I bought the one on the right when I bought my Honda HRX and found it works a lot better due to the curved edges.
If you have it really wet on the Kubota anyway I normally can take a water hose and wash it out pretty easy. Ir it starts off wet in the morning and dries off rapidly during the day then it is harder to get off late in the afternoon or evening with just water pressure.
Yeah....I am hesitant to use water, because if you get it in the wrong places it can mess stuff up!
