mitchstein443
- Nov 2, 2018
- 55
I have a Craftsman II 1979 lawn tractor with a horizontal 18HP Briggs and Stratton twin cylinder engine.
It will start on starting fluid and then run just fine on gas.. Once warmed up most of the time will start immediatly on just gas.
Things I have done so far..
Cleaned and gapped and tested plugs.
Tested for spark on both cylinders.
Tested compression in both cyclinders both cold and warmed up. within 10lbs of each other both ways..
rebuilt carb, replaced float, needle, blew out all holes and tanked in safety clean over night.
Replaced vacume fuel pump with 4 psi electric pump and 2 psi regulator (tried with and without regulator, never dumped fuel into the oil and fuel filter is always full)
replaced all fuel lines, filter, and cleaned out gas tank..
It can not be a carb solenoid because this model doesn't have one..
Things I think that might cause it, but want to confirm before taking the entire frontend of the tractor/mower apart)
valve adjustment, coil adjustment (although always has strong spark)
Other then those two things I can not figure it being anything else.. I have mowed for over 2 hours with it once it is started, and then shut it down and it fires right up, but if I wait two or more hours I have to fire it on starting fluid then runs perfectly...
I am an amature small engine guy, I know car engines though and the principles seem the same. So this question may be elementary to you guys, I am looking for either confirmation of my suspected problems or the dr. house in this bunch to come up with something I can't find on google.. lol..
Tanks in advance, and I will post a followup explaining the resolution in detail.. I am retired and fixing riding mowers in now my hobby... I pick them up from barns and garages get them running and then either give them to veterines or sell them and donate the money to non profits.. Or as my wife hates, I just keep them... I have a 200ft by 20 ft yard with 5 working mowers right now, lol..
