Engine will not start
simplymike
I have a simpicity 16GTH it will not start. I mowed the yard,shut it off to clean it up and now it will not start. I did not use any water to clean just air. I have spark,I have taken out plug and put a little gas in it there and still will not fire up,it seems to be blowing air back through the carburator. I would be greatfull for any help with this problem. It has a 16 hp twin vanguard engine. Thanks
motoman
Mike , go to the troubleshooting charts in this forum, then ask for help.:thumbsup:
KennyV
Hello Mike... WELCOME to these Forums....
To get any engine to run, all you need is enough compression + enough Fuel & air + enough spark... all happening at the correct time.
Start out with the easiest, spray some 'starter fluid' (ether), or flammable carburetor cleaner Directly into the carb While cranking the engine... Post back with the results... :smile:KennyV
simplymike
Thank's for the input guy's I found some sticking valves, should be up and running in a day or so. Thank's again, Mike
