Sturgisatv
I do not know why the push rods bent & broke the 1st time. About three or 4 seasons ago the mower started popping and my son-in-law replaced the push rods on the vacuum fuel pump side cylinders he also adjusted them ( He is a airplane mechanic for jet blue) last season it started popping again sometimes so I replaced a bent one on the same side. Then at the end of last season I had the problem with starting.
Now I have adjusted the valves on both sides and it starts using the new starter motor if I jump Positive side of Battery directly to starter. Have checked out Solenoid and seems defective. going to buy a new one and install.
I'll let you all know if that is the last link in solving my mower problems
Thanks for all you guys help
gperna
gperna
