Ric
- May 7, 2010
- 139
- 5,765
Ric, I'm also curious why you are promoting the 22 hp Kohler. When I compare the three RZT-S models on the Cub Cadet website, they all appear to have the Courage 725cc engine but the hp varies. The 42" cut has a 22 hp engine. The 46" cut has a 23hp engine. And the 50" has a 25hp engine. So I wonder if the engines are in fact basically the same, and what they are doing to increase the hp for the bigger mowers.
So Ric, why do you like the 22 hp Courage over the more powerful engines?
For one I don't believe the RZT-S is going to solve your problem as I said before. I feel like the only one of the three that you would have any chance with for the application you describe would be the 22 HP.
I'm not promoting the 22 hp Kohler but I've said for a long time that when people buy mowers they do not do the research they need to do before making a purchase. To many people buy a lawn mower based on engine size and name on the mower which IMO is crazy. Out of the three mowers you mentioned which are you buying?
Personally I run two Kohler Courage Motors, a 20 and 22 HP and I've had real good luck with the Kohler motors but the type of motor doesn't concern me as much as the HP rating.
