ottoslanding
- Sep 1, 2013
- 3
- 26
They say china on them
(( cowboy up and get over it ))
The pulley arrived and it had the bearings in so I don't know what they say on them. I saw no markings on the pulley. It looks exactly like the one that came off the mower and I am guessing the pulley was put on in the factory but I do not know that to be fact.
I pulled off the tensioner spring with my hand and checked the tensioner arm for play and I can feel no play in the assembly.
For removing the pulley I used a small cordless impact wrench on the bottom hex bolt while I held the locknut on the top of the tensioner arm with a ratchet and socket. This is all being done with the rear end in the air and on jack stands, the front wheels chocked and the left wheel removed.
When replacing the pulley I was able to star the bolt through the tensioner arm from below and then start the locknut on the top with my other hand. With the pulley assembly now suspended, I simply reversed the removal procedure. I did use some loctite 242(blue medium strength) on the pulley bolt threads to help the locknut.
The old pulley has some slight play in the bearing hub and the new pulley has no play.
The whole process took less than 30 minutes.
I did a follow up on the coolant. Here is what the Kawasaki engine owners manual states:
Recommended Coolant Solution
Water 50% : Antifreeze 50% (1:1)
Recommended Antifreeze:
Permanent type antifreeze (ethylene glycol plus corrosion and rust inhibitor chemicals for cast iron engines and aluminum radiators.)
I am nearly positive when I asked my scag dealer they recommended the old school green type antifreeze
I did take off the radiator screen and blow that off with compressed air and likewise with the radiator. Also pulled the two air filters and housing and blew it out.
Now just waiting for my belt as I watch my grass grow.
:tongue:
