Carscw
- Aug 11, 2011
- 66
- 6,375
You can run a wire from the coil to the key switch and bypass all safety switches.
Or can check the seat and clutch switches Start with the seat switch and unplug it if still no spark then jump the two wires together if that's not it then do the same to the clutch / brake switch.
I would just install I on/off switch
Sent from my iPhone using LMF
