Which type of TORO Titan blade for long grass?
JR1
I have a Toro Titan ZTR. When I use it in long grass (4.5 inches-6 inches) to enable a good clean mow, I either need to drive extremely slow or mow twice. Otherwise, I am extremely happy with my new machine. Is there a type of blade that works better than another in tall grass?
Low lift blades work best in long grass
Mulching blades work worst
A bad cylinder will cause the engine to loose power in long grass & slow down
I have had more than one customer come in with your problem to find they are running on 1 cylinder
jasson123
Hey , I've checked toro lawn mower on this article it has all the info about it , it might help you ...
JR1
Thank you Jason 123...what a pleasant surprise to wake up and read this post.
MParr
Low lift or standard lift blades and discharge chute in the up position or removed. DO NOT use mulching or Gator style blades.
