I had problems after using some five month old gas for my Craftsman chainsaw and had to replace the spark plug and fuel filter. From now on I plan on using Craftsman 40:1 2-Cycle Fuel Mix.
It only costs $5.49 a quart. That is enough to meet my needs seeing I never use up the gallon that I mix. I only use the chainsaw to remove a few old bushes, small trees or fallen branches. Other than that it sits around for a long time between uses.
The pre-mixed fuel lasts two years and uses synthetic oil. I will update everyone on how it works in the spring when I remove a couple small trees in the back of my father's place. It will be nice to not worry about the fuel going bad after only a few months!
The spark plug I removed was fouled up a bit. Also Craftsman stuck a Chinese plug (Torch) in it instead of a Champion plug that they recommend in their manual. What's up with that?
It looked cheap.
I replaced it with a new Champion plug.
It looked cheap.
