Which solenoid for YTS3000?
Tree_farmer2
Can you help me find the right solenoid for a Craftsman YTS3000 riding mower?
It has 2 big 12 volt posts on top and 2 blade-type posts
The numbers on it say:
Trombetta 862-1241-211-12. 12V
What would be a compatible solenoid for this mower?
Thank you!
IT is called a 12V 4 pole solenoid
Nothing special or unique and now days most are universal so they have 2 sets of brackets for mounting vertical or horizontal
To me it is a single pole switch with four posts. The main posts are usually rated from 100 amps to 200 amps. Suggest using the 200 amp version. The two smaller post is the trigger coil terminals.
