Tombstonebilly
- Aug 25, 2012
- 15
- 41
Do you cut with a back and forth pattern or do you do a square pattern and why/
I personally like the back in forth method and mulch but that's just me, as to which is faster, time wise there's really no difference If your mowing in a square pattern. The total number of angular degrees you turn is in either case will be the same. I mow back and forth when I can because it just makes thing look better.
I agree I go back, and forth too it looks much better.
Just like the looks better back and forth
Yes. I have tried both ways, and the time didnt vary more than a few minutes. It seems like back, and forth keeps you in the grass more reducing your cutting time.
