where does the yellow wire go
Jammer48
I have Cub cadet 1440 with a B&S 294447-0445-01 that I am assembly back together but I have a yellow wire coming from the wire harness that I don't know where it goes! Any ideas?
IF the mower is running fine then don't worry about it.
The wiring harnesses are universal made to fit every engine that could have been fitted and all options.
As such you end up with the odd orphaned wire for things like hour meters , oil lights , alternator warning lights etc .
IF the mower is not working properly then tell us what it is not doing which will point to where the wire might need to go .
Scrubcadet10
Moderator
Staff member
What kind of connector does it have on it?
post a picture if you can.
Jammer48
here it is
Scrubcadet10
Moderator
Staff member
have you checked for power on it?
Jammer48
no i will do that now hang on....no power with key off or on at any level of the switch... I did check for continuity and it is a ground cable apparently
Richard Milhous
I dunno crap but I'd think "headlights". The resistance of a headlight bulb is low enough to show continuity with ground, and a ground wire wouldn't be yellow. I friggin' hope not anyway.
Jammer48
Thank you for your reply the lights already have a dedicated connector and work as they should
Benge
