My Z50 EZT gearbox drives have two flat side that fit into the axle hub. There is "slack, movement" between the flats of the axle and the wheel bore itself.
I'd appreciate ideas as to how to tighten up the wheels/hubs.
Things I have considered: 1. Spot weld the axles, file down to fit the wheel...worried about excessive heat on seal
2. Metal shims between axle and wheel hubs...probably would beat them out over time.
Thanks in advance,
bartles
Thanks in advance,
bartles
