l008com
- May 25, 2015
- 40
- 238
I have a Craftsman yard vacuum. It actually works pretty well. But my yard is kind of rough and the thing has small wheels so I bought a pair of giant 12" wheels to help it roll smoother. They actually fit really well, AND turns out there's a second position I can put the axle in to help accommodate the bigger wheels.
But the one glitch in this plan is that the "hub" portion of the new wheels is a lot wider than the original wheels. So I need a longer axle. This axle is not threaded, it's just a perfectly straight rod with a pin hole on each end.
The OEM axle is 20.5" wide. Looks like I need one that is 22 3/8" wide. (or a little wider, I can always pad it out with extra washers). Anyone know where I can get an axle like this? I gotta assume that some piece of equipment out there probably takes this exact axle and I could just swap it in. But I'm not sure how to look for it. Is there a name for this type of axle, with the pin holes instead of threading?
