- Nov 29, 2014
- 65
- 24,995
Sounds good.
Post a couple of pix when it is done & don't forget the paint.
The usual culprit for rusting out decks is allowing clippings to sit on the deck
So BLOW down the deck when you have finished mowing and DO NOT USE WATER.
Dry grass clippings will adsorb lots of water & are quite acidic and acid water promotes rust.
Just about every paint, is porus which is why you need to use at least 2 coats on everything that is used outdoors.
I use a compressor & a 4' long air duster.
others use a leaf blower.
If necessary cut some blow paths in the pulley covers to aid blowing them out.
