What's Going On With This 20hp V Twin? (Video Inside)
JonnyBlaze
  • / What's Going On With This 20hp V Twin? (Video Inside)
Model: 441577
Code: 051013YH
Type: 0113 E1
Does this mean the valves need to be adjusted or is it something more serious?
https://youtu.be/KcOoUMzF8Pc
Thanks in advance.
Valves need adjusting.
Won't hurt to clean all of the heavy power connections ( ground included )
JonnyBlaze
Ok. I've never adjusted valves on a v twin. Do you know of a good video or write up? Thanks.
Luffydog
May also find out it might not be just the valves.
Luffydog
Could also be a worn cam
Or a shifted valve guide but we won't know either till the gaps have been checked.
Luffydog
Yes true but at this point can't just say the valves could be but also could be all the above as well. Until they are check
And set and ran and then compression taken and leakdown can't just say valves and rule out the all other possibilities.
I don't think a worn cam, because he got it pass the compression stroke and it fired right up.... It also ran great.......
Yes we will find out the issue when JB does post it.......
