WHAT TYPE OF MOWER DO YOU USE AS YOUR MAIN MOWER?
WHAT TYPE OF MOWER DO YOU USE AS YOUR PRIMARY MOWER?
  • Total voters
    151
mikehouse
Husqvarna HU700F GCV160 for the way bigger front yard.My Lawnboy siver series 10330 for the flatter back.20200411_081712.jpg20200411_081630.jpg
mikehouse
Can someone explain these to me.I wanna know what year this mower was made.I see 2014 but is that for the law or this model?20200411_100804.jpg20200411_100857.jpg
able43
I use a 52" Gravely ZT XL ZTR just now reaching 100 hrs after 5 years
mikehouse
Hi.I always notice people say how many hrs they've gotten on their machines,and in so-and-so time.So do these riders have like a timer or counter or clock on them?
able43
Hello and thank you for asking your question. Many riding mowers now and even years and years ago have hour meters that allow you to track the time spent running and using the piece of equipment. Also for tracking and performing PMCS. Now sometimes you can get inaccurate hour readings if the key of the equipment is left in the on position thus powering the hour meter by closing or opening its circuit to give it the needed power or either the proper avenue to ground.
mikebarber
Toro Reelmaster 450d 11 ft cut diesel and a Hustler Fastrack 48 inch GO BIG OR GO HOME
oh and a STIHL 075 chain saw 111 cc's
Rocky J
I have a Troybuilt ZTR 24hp 50 inch , Woods 52 inch out front 18hp , Toro GM72 72inch out front 28hp Renault engine propane and a 1964 Cub Lo Boy 60 inch belly with C60 cubic inch propane . My yard is 4.5 acres with gophers, so ruff seat time. The tires on the cub LoBoy are 50 inch tall and step over the holes where the others three mowers with small tires can beat me up after a hour. The Cub is a threat of a broken leg with ever mount and dismount and is low Horsepower , much better power on propane than gasoline , about 3 gallon x 98 cents to mow the yard, But for it being a gutless leg breaker it is my favorite to mow with but of course I pick the Troy Bilt to trim with because it is short and fast, the out fronts have there place like under bushes and inside corners but are long tailed , but will trim around a pop can.
