What sensor is this Murray riding mower
Scrubcadet10
Moderator
Staff member
I need to go get my eyes checked.
Justwayne
Cool so it's a bulb socket? Noticed the mowers never had headlights that worked or harness just empty headlamps in the hood. It was down under the belt up around rear axle unplugged at the connector. Seen it goes right up to the key switch. Do some Murray mowers not have functional headlamps? Ever since I've used it seen it didn't have the headlamp harness or sockets under the hood. It was my grandfather's Murray bought from Walmart in 2004.
tom3
Some older Murrays have the shift on the fender and a reverse lock out contact piece there.
Justwayne
tom3
We might be missing something here. Does the mower run like it should?
dougand3
Post the LT model #. On fuel tank label or under seat. Type it out - don't try to take a pic of it.
Justwayne
Believe it is the headlight harness. It has the second set of spade terminals. A few years ago went to see it doesn't have headlights so couldn't cut grass in the evening. I just seen harness wrapped around the belt up to the rear axle. Nice anyone know the correct part number replacement harness with the bulb sockets.IMG_20201024_111650.jpg
250X92MA
And here what the light socket looks like, just make sure it is what you are looking at as the images posted are pretty blurry.
Fish
He might just need to clean off his lens a little.
