Bjarne
- Aug 13, 2023
- Threads
- 1
- 3
Sorry for my bad english i hope you understand what i mean.
I have an older snapper zeroturn, and I have problems finding out wich oil i should use for the hydrogear.
I found a manual online for my machine, and it says i should use 20w50 engine oil on the hydro. But on the top of the cap for the oil, it says I should only hydraulik oil? Also I have found af video on YouTube with a man changing some broken lines on a mower almost identical to mine, and he also uses hydraulik oil on the machine.
So which oil should I use?
And one more question.
I have seen some videos of people changing oil on the hydro drive. In the manual to my machine it says nothing about how ofte i should change the hydro oil, in fact it states under the sektion about filter change that i should NOT drain the hydro gears for oil when I change the filter(there is only 1 hydro filter between the hydro drives, and not 1 filter in each drive)
Can it be true that the hydro oil is not supposed to be changed in my zeroturn, and I should only change the filter and top up the hydro oil if needed?
