What model is this mower? Please help ;(
Stiny
Hello. I wasn't sure if this was the forum to ask about an equipment brand and model. Please let me know if I need to remove or move the post.
I have two pictures of a mower but cannot seem to find the brand or model. More exactly, I am looking for replacement blades for the mower, and that is why I am looking for the model.
I kindly ask if anyone knows what model the mower in the pictures is.
Thank you.
My crystal ball is still out of order here.
Looks like an older Land Pride Rotary Cutter. Model number would depend on size. That’s the best guess coming from my crystal ball.
Stiny
Is there a place I could get the following blade?
rotary blade is 4 in. x 18 in. x 3/8 in. with a 1 in. bolt hole
I would check the yout local farm implement dealer. Most are able to get you the blades you need. Remember to take a blade with you. They will be able to measure and match the blade so you don’t have to pay a restocking charge if your measurements or angles are wrong.
LMPPLUS
Thank you.
