Skippydiesel
- Nov 29, 2020
- Threads
- 15
- 314
Gentlemen:
More Power:
Retired now but whole career in agriculture. Doesn't matter what you are processing, the more you process (in this case render the grass clippings smaller) the more power is required - simple physics.
No matter the size of your machine (push or ride on), an identical one, without mulching kit, will use less power than the one that has it. This can be translated in to less fuel burnt per unit area (acres or hectares) or less time to cut.
Fertilizer:
I have never removed grass clippings from my lawns - thats what worms/fungi/insects are for (incorporating organic matter). Removing grass clippings is much the same process as harvesting/grazing a crop - by doing this you are stripping nutrients from the soil, leading to nutrient deficiency. If you want to maintain a health grass cover/lawn, you will have to replace the nutrients lost, by fertilising (chemical or organic). In my view a crazy notion.
Blades Cut Multiple Times:
There will always be a degree of material "churn" within the cutting cavity - its just not possible to eject each cut grass clipping without some recut However this is not the intention. If your mower deck has been correctly adjusted, there will be minimal recut/processing.
Think of the blade as a disc, with one side, half of the disc, being the forward/leading edge (cutting arc). For most effective, least power required, operation, the disc should be set so as to achieve a leading edge down angle ie as the leading edge leaves the cut sward, so its trailing edge (arc) should be fractionally above the cut material. No additional cut or drag, so lowering hp requirement.
More Power:
Fertilizer:
